[Copied from topic]Note: while division by zero is popularly thought to be equal to infinity, this is not technically true. In some practical applications it may be helpful to think the result of such a fraction approaching infinity as the denominator approaches zero (imagine calculating current I=E/R in a circuit with resistance approaching zero -- current would approach infinity), but the actual fraction of anything divided by zero is undefined in the scope of "real" numbers.
[End of copied material]
It's not even technically true if you allow for negative denominators that are close to zero. Assuming a positive numerator and a positive denominator, the value of the fraction increases without bound (approaches infinity) as the denominator approaches zero. If the denominator is negative, however, the value of the fraction decreases without bound (approaches negative infinity) as the denominator approaches zero. These can be stated much more succinctly using one-sided limit notation.
Quotes aren't needed around real in "real" numbers. Division by zero is also undefined for complex numbers.
