All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > General Electronics Chat
General Electronics Chat Discussion forum for general chat about anything electronics related, including asking questions about material in the All About Circuits E-book, Worksheets, and Videos.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 11-08-2009, 08:55 AM
gusmas's Avatar
gusmas gusmas is offline
Member
Default Need some help with Orcad Layout
hey i need some help with orcad layout, i will briefly exlpain my current problem. When i am done placing all the footprints of the components then i go to autoroute and it routes all the tracks for my circuit. I am using a single layer pcb, now when autoute is done some of the tracks run over the footprint of certian components like in figure 1, is there no setting in orcad that can prevent this "problem". Figure 2 is how i actually want it.
Because when i solder and the tracks run to close to the pad , it will be extremely difficult to solder and not let any solder run onto the tracks surrounding it.
  #2
Old 11-08-2009, 01:52 PM
Duane P Wetick Duane P Wetick is offline
Member
Default
It looks like your minimum circuit line width and minimum width between lines is not set correctly. Adjust the minimum width(s) and you will solve the problem.
Cheers, DPW [There is no computerized explorer in the world with more than a tiny fraction of the power contained in the chemical analog computer known as the human brain, whose reproduction is easily accomplished by un-skilled labor. WVB]
Bookmarks
Tags
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Orcad layout library voduychau Electronics Resources 10 06-14-2009 04:19 PM
IC Layout Mazaag General Electronics Chat 4 09-03-2008 02:15 AM
need help in ORCAD layout !! lesin akbar Electronics Resources 3 01-30-2008 04:52 AM
DRC tutorial for OrCAD Layout 9.2 kender Electronics Resources 1 09-28-2007 09:00 PM
How to link a model to an OrCAD PSpice schematic? kender Electronics Resources 5 04-28-2007 09:06 AM
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Copyright © 2009, All About Circuits. All Rights Reserved.
