Clamper Circuit
dezurtrat
Joined Dec 9, 2008
The clamper circuit (DC Restorer) shows the Source Voltage V4 in figure (a)as 5Vp-p but the graph is showing full 10V swings. Isn't that 10Vp-p?
I think V4 in figure (a) should be labeled 5V peak and not 5Vp-p. Yes/No?
http://www.allaboutcircuits.com/vol_3/chpt_3/7.html#23028.png
EDIT: Also, the diodes in figures (a) and (b) are showing 4.3V across them. That should only be 0.7 volts across the diode alone I believe.
Wendy
Joined Mar 24, 2008
23,797
This one is a bit tricky. I believe you are looking at the back bias of the diode, in which case the 4.3V is correct. The capacitors are charged to the voltages needed to turn the diodes fully off, which is shown in the illustration.
You are correct about the 5V P-P problem, I believe the author meant to show 5V P and slipped. When I get confirmation I'll post the redrawn pictures for the editors.
dezurtrat
Joined Dec 9, 2008
I believe 5V peak would be better as it is that way on the previous page on the clipper circuit diagram. Stays consistent that way IMHO.
Thanks!
EDIT: Yes my mistake as the diodes are reversed biased! Doh!
