| The Projects Forum Working on an electronics project and would like some suggestions, help or critiques? If you would like to comment or assist others with their projects, this is the place to do it. |
Thread Tools | Display Modes |
#2
If you are going to use a voltage higher than 12V to power the relay you will need a resistor in series with the relay coil to limit the current through it to a safe value and do not destroy the relay. If you will use a 12V supply connect the relay coil directly to it. In both cases, you will connect the capacitor in parallel with the relay as when the power is switched off the relay will stay energized for a few seconds. The time it will remain energized depends on the capacitors value, the resistance of the relays coil and the pull-out voltage of the relay.
If you measure the resistance of the coil with a multimeter then the time will be approximately equal to: t=-RC*ln(V/Vm) where R=coil resistance C=capacitance of capacitor V=pull-out voltage Vm=initial voltage across the capacitor (working voltage of the relay's coil)
__________________
>> Troubleshooting is an art << http://www.youtube.com/watch?v=hC7KYbFBPHA http://www.youtube.com/watch?v=StNJlRTWs9k http://www.youtube.com/watch?v=j-4h3l9O4fc http://www.youtube.com/watch?v=E0jZJ...eature=related |
#3
Thanks mik3
For "C=capacitance of capacitor" is the units μf (microfarads) of F farads ?? im guessing Farads also - i'm using a 9V battery so if i add a resistor it would slow it down right? whats the limit to the size of the resistor i could use?? i don't think the formula takes into account the cut off current if i had a 50kohm resistor then the formula would= (-50 000) * 0.001 * ln(1.2 / 9) = 100.745151 but the current would be= 9 / 5000 = 0.0018 |
#4
Don't think so, think in terms of a 1/10 of a second. 1 RC time constant = R C = 150Ω X 1000μF = .150 sec. I suspect you're going to have to build a timer connected to the relay. I didn't bother figuring a divider circuit. You could even use a transistor to boost the time, it doesn't need to be that fancy.
******************************** Here is something I sketched out. Never built it, but it should work. You may need to use a Darlington transistor to extend the time. R2 will adjust the voltage down where the relay won't fry, and R1 might not be needed at all. A 555 version will be much more predictable, with a slightly higher parts count. I'd be glad to sketch that up if you want.
__________________
.. "Good enough is enemy of the best." An old engineering saying, Author unknown. General info: If you have a question, please start a thread/topic. I do not provide gratis assistance via PM nor E-mail, as that would violate the intent of this Board, which is sharing knowledge ... and deprives you of other knowledgeable input. Thanks for the verbage Wookie. Last edited by Bill_Marsden; 11-21-2008 at 08:38 AM. |
#5
[QUOTE=RiG615;99809]
so if i add a resistor it would slow it down right? QUOTE] No, you wont slow it down, it wont get energized at all! The only way to increase the time is t oincrease the capacitor value or use a relay with greater coil resistane or make the circuit Bill suggested. About the capacitor value it must be in Farads.
__________________
#6
The problem is the length of time (5 seconds is a long time in electronics) and the relay (which is pretty low ohmage on the coil, check the specs out). A very rough rule of thumb is the RC time constant (which I showed previous), R X C = Seconds. K in ohms is X1000, and µF is X 0.000001F . The transistors gain increases the apparant resistance on the emitter (the arrow) to increase the RC time constant.
It occurs to me you may not have a clue what I'm talking about. Feel free to ask questions and we'll do our best to answer them. If you were to make the capacitor 20 to 100 times bigger you would be in the range you're looking for, but 100,000µF is not a small part, in fact it is physically huge.
__________________
.. "Good enough is enemy of the best." An old engineering saying, Author unknown. General info: If you have a question, please start a thread/topic. I do not provide gratis assistance via PM nor E-mail, as that would violate the intent of this Board, which is sharing knowledge ... and deprives you of other knowledgeable input. Thanks for the verbage Wookie. |
#7
Thanks Bill,
Can you explain whats happening and how your sketch works? i don't think i fully get it. -thanks |
#8
In a common collector circuit the apparent resistance from the base to ground (through the emitter) is the gain of the transistor (β) X the emitter resistor. Figuring the resistor is around 180Ω and β is 50, this brings the resistance up to 9000Ω. 1000µF X 9KΩ = 9 seconds.
You can read more about common collector transistor layouts here.
__________________
.. "Good enough is enemy of the best." An old engineering saying, Author unknown. General info: If you have a question, please start a thread/topic. I do not provide gratis assistance via PM nor E-mail, as that would violate the intent of this Board, which is sharing knowledge ... and deprives you of other knowledgeable input. Thanks for the verbage Wookie. Last edited by Bill_Marsden; 11-22-2008 at 09:28 AM. |
#9
Rig,
Just to clear things up, Do you want the relay to stay on for a while after you switch the power off or you want to switch the power on and the relay to be energized after a while?
__________________
#10
mik-
I want the relay to stay open for a while when i switch the power off |
| Tags |
| capacitor, hold, open, relay, resistor |
Related Site Pages
| Section | Title | |||
| Worksheet | Time-delay electromechanical relays | |||
| Worksheet | Protective relay circuits | |||
| Worksheet | Electromechanical relay logic | |||
| Worksheet | Capacitors | |||
| Video Lecture | Electronic Components - Basic Components and Technical Notation | |||
| Textbook | CMOS 555 LONG DURATION FLYBACK LED FLASHER : 555 Timer Circuits | |||
| Textbook | Fail-safe design : Ladder Logic | |||
| Textbook | Solid-state relays : Electromechanical Relays | |||
| Textbook | Time-delay relays : Electromechanical Relays | |||
| Textbook | Relay construction : Electromechanical Relays | |||
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Relay + MP3 Player + lights project | airforce1j | The Projects Forum | 1 | 06-25-2008 06:10 PM |
| Doorjamb Switch with 24volt Relay? | dwayne | The Projects Forum | 2 | 04-29-2008 02:45 PM |
| 12 vdc Relay problem | timc4444 | The Projects Forum | 8 | 03-15-2008 02:58 AM |
| Is this Relay setup possible ? | swifty | General Electronics Chat | 6 | 02-01-2008 08:12 PM |
| EFI Fuel Relay Problem | akajee | The Projects Forum | 4 | 01-26-2008 08:18 PM |
| Thread Tools | |
| Display Modes | |
