How much charge can a capacitor hold?
Discussion in 'General Electronics Chat' started by impaJah, Aug 3, 2012.
  1. impaJah
    Aug 2, 2012
    18
    Is there a way to calculate how many coulombs of charge a given capacitor can store given a certain time interval that can be derived from its farad rating? For instance, how many coloumbs can a 47uf cap hold after 2ns of 3 volts? What about a 1uf? Or a 500pf?
    If it can't be derived from it's rating, is there another convenient way to figure this out?
  2. MrChips
    Oct 2, 2009
    12,657
    3,461
    The charge Q in coulombs is the capacitance C in Farads multiplied by the voltage in Volts.
    Q = C x V
    For example, 1μF x 5V = 5 μC
  3. impaJah
    Aug 2, 2012
    18
    Thank you MrChips!!!
  4. crutschow
    Mar 14, 2008
    13,527
    3,393
    The capacitor voltage (Vc) after an interval of time is determined by the voltage charging source (Vs) and any resistance (R) in series between the voltage charging source and the capacitor (C). The capacitor voltage will rise exponentially after the voltage is applied and will be equal to Vc = Vs(1 - e^{-t/RC}) where t is the elapsed time.
    From the capacitor voltage you can then calculate the charge using the formula MrChips gave you.
