All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > General Electronics Chat
Notices
General Electronics Chat Discussion forum for general chat about anything electronics related, including asking questions about material in the All About Circuits E-book, Worksheets, and Videos.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 11-05-2008, 03:43 PM
momofthree momofthree is offline
Default magnavox tv has no picture or sound
After working fine a few hours ago, our magnavox tv will not display a picture. When the "power" button is pressed the tv will make the clicking sound that, in the past, as indicated that it is on. However, there is no sound or picture. The cable modem displays that power is available there. We have unplugged and plugged the unit to no avail. Any suggestions or diagnosis would be great! Thanks.
  #2
Old 11-05-2008, 04:01 PM
SgtWookie's Avatar
SgtWookie SgtWookie is offline
Expert Member
Default
Welcome to the Forums.
How old is your Magnavox TV?
If it's getting close to 7 years or more old, it's probably not worth getting it repaired.
Since you hear the "click", that's enough evidence for me to indicate the set has power to at least the standby circuits. There are a number of protection circuits in the set that will shut it down if a fault is detected, such as voltage levels that could result in X-ray emissions.
TV's can easily become damaged if there are voltage "spikes" on your household AC voltage supply.
I do not recommend opening the case of the TV, unless you're an experienced technician. Even weeks after power has been removed, very high voltages may still be present; 14kV to 20kV. Accidental contact with such voltage levels can be lethal.
Even LCD TV's have lethal voltage levels to drive the CCFL lamps (cold cathode flourescent).
__________________
General info:
If you have a question, please start a thread/topic. I do not provide gratis assistance via PM nor E-mail, as that would violate the intent of this Board, which is sharing knowledge ... and deprives you of other knowledgeable input.
  #3
Old 11-05-2008, 08:56 PM
Default Thanks.
Thanks for the response. The tv is about 3 years old. Do you think it would be worth getting repaired?
  #4
Old 11-05-2008, 10:50 PM
theamber's Avatar
theamber theamber is offline
Default
I will tell you a rule of thumb about something being worth repairing;
First it does not matter how old is it unless the CRT shows burned or the picture being washed out.
Second look at how much it will cost the repair versus replacing it by a new one.
Third most repairs should carry a 3 months guaranty.
Now, your TV is energizing the relay (that is the clicking sound) as it was said it could be the 'high voltage shut down' circuit that is activating the power shut down or the HVSD could be ativated by an overload some where in the power supply or the HV horizontal if it is a CRT type. If you don't have the schematic is going to be guessing. You should get a free estimate from a repair shop.
The highest CCFL inverter supply that I have seen it had 830 Volts, the big majority are around 350 V.
__________________
Minds are like parachutes. They only function when they are open. Sir James Dewar, Scientist (1877-1925).
Imagination is more important than knowledge. Albert Einstein.
I haven't failed, I've found 10,000 ways that don't work. Thomas Edison (1847-1931).
Do just once what others say you can't do, and you will never pay attention to their limitations again. James R. Cook.
  #5
Old 11-05-2008, 11:55 PM
Default Thank you.
Wow, what wonderful people are here. The only electronics exposure I have had is high school physics! Thanks for all of the advice.
  #6
Old 11-06-2008, 12:52 AM
Audioguru Audioguru is offline
Banned
Default
Magnavox is Philips. Their TVs are made in China now like all the others.
Today you can buy a CRT TV for almost nothing.
  #7
Old 11-06-2008, 01:18 AM
SgtWookie's Avatar
Expert Member
Default
Sorry I didn't get back to you sooner.
If it's only three years old, it may be worth having it repaired, particularly if it's HDTV capable.
It depends upon how much damage was done when it stopped working.
Sometimes, the damage is limited to a couple of inexpensive components. The expense is then mainly the time it takes for the technician to find and replace the parts. While all televisions perform similar functions, the internal designs are quite different.
Stiff competition has forced manufacturers to design most consumer products to be produced as cheaply as possible; most shoppers will choose the least expensive product that has the features that they need. This often results in products that don't have as long of a lifespan as otherwise might be achieved.
You can still buy high-quality, long-life products, but they're very expensive, as they are not produced en mass; as the vast majority can't afford them.
But I'm rambling - sorry 'bout that.
Ask your friends for recommendations on local TV repair shops.
If you have cable or satellite TV, call the cable/satellite TV company and inquire if your cable/satellite has been cut off.
Take the set to the shop. Having a technician visit the house nowadays is no longer affordable, if you can even find someone who will do that. Ask for a quote before repairs are made.
Some components are quite expensive, like the flyback transformer. If the flyback transformer needs replacement, just the part itself frequently costs over $100 (not including installation) - and then you'll have a 3-year-old TV that might last another 3-4 years.
These kinds of things are pretty difficult to diagnose via the Internet.
However, I had something similar happen to one of our TV's.
We have a 32" Zenith that's a few years old. One day, it suddenly went from working just fine to no sound, no picture, and an odd "snap" sound coming from the set every few seconds. After purchasing a Sam's Photofact online and downloading it, I determined that a Zener diode had shorted out, causing a resistor in the protective circuit to get burned up. I replaced both the Zener diode and the resistor, and the TV has been working just fine for the last two years.
But your story may be completely different. I am not suggesting that you attempt to diagnose the set yourself; you need proper training and experience to do that.
In the meantime, while the TV set is in the shop, take the kids down to the public library. Get them reading.
TV is highly overrated.
__________________
General info:
  #8
Old 11-09-2008, 01:51 AM
Default
Thanks, SgtWookie!
I enjoy your insight. If there was not a weather channel addict in the house, we could probably do without. It has now been 4 days, and no one has missed it yet! Thanks again for your time.
Tags
Related Site Pages
Section Title
Worksheet Basic troubleshooting strategies
Video Lecture System Connectivity - Electronic Systems
Similar Threads
Thread Thread Starter Forum Replies Last Post
PIC Sound Card CVMichael Embedded Systems and Microcontrollers 3 06-22-2008 02:57 AM
Computer sound level measring anaskoara Computing and Networks 6 03-25-2008 06:30 PM
How to connect a sound circuit to a transmiter anilson General Electronics Chat 1 10-03-2007 03:47 PM
Pioneer PAL007A - unwelcome sound zdeny General Electronics Chat 2 01-31-2005 05:01 AM
Pioneer PAL007A - unwelcome sound zdeny General Electronics Chat 1 01-29-2005 11:40 AM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, vBulletin Solutions, Inc.
