Magnavox Rear Projection TV Problem
Discussion in 'Technical Repair' started by hondabones, Nov 7, 2012.
  1. hondabones
    Thread Starter Active Member
    Sep 29, 2009
    123
    I've been asked to look at this TV. It takes a long time to turn on. Any ideas as to what causes this?
    Thanks.
  2. crutschow
    Mar 14, 2008
    13,493
    3,372
    Is it an old CRT type rear projection TV? Post the model number.
  3. hondabones
    Sep 29, 2009
    123
    Yes, it is, Actually it may be considered a front projection TV but same idea.
    Model: 55P8288A
    Chassis: PTV910
  4. crutschow
    Mar 14, 2008
    13,493
    3,372
    If it's slow to turn on then it may be the picture tubes going bad. To get the desired brightness the small tubes were driven very hard and thus tend to have a shorter life than a standard CRT TV. Likely not worth fixing, especially with the low prices of flat panel TVs now.
  5. Audioguru
    Dec 20, 2007
    9,411
    896
    My 8 years old Sony 32" CRT TV failed then I replaced the burned out parts and it worked for 1 week then the same parts failed again.
    I phoned a few TV repair places and offered it free if they take it away. None wanted it.
    I advertised it in Kagigi and a guy came, picked it up all by himself (it weighed a lot) and gave me $25.00 for it.
    Then my son bought me another newer and better Sony 32" TV for only $60.00.
    So the replacement TV costed me only $35.00. It is newer and better than the original and it works great.
    I don't need a thin flat huge screen HD TV "yet". My daughter has one that is HD and 60".
    My son bought a used TV projector and a remote controlled screen. Its image is HD, very bright and is HUGE.
  6. Brownout
    Jan 10, 2012
    2,375
    998
    I gutted an old crt type rear projection TV and used the case for a portable big screen LCD TV. The case was oak and too nice to throw out. I'm planning on using the screen with a rear projector for maybe movie nights in the back yard.
  7. hondabones
    Sep 29, 2009
    123
    I kind of figured this was the problem. I'm not familiar with TV repair. I did pull the back off and attempt to have a look but it honestly seemed to work correctly. Thanks for the response.
  8. doller
    Sep 28, 2012
    14
    The Fresnel lens could bring in some cash. Or be used for interesting stuff like cooking with sunlight.
