Issue: Magnavox 27" TV HD2763-C401
Discussion in 'General Electronics Chat' started by scottalanreed, Dec 5, 2012.
  1. scottalanreed
    Dec 5, 2012
    I love this TV. Really reliable and a great picture.
    My wife was watching it last week and heard a hssst! And now there is a large rainbow-colored circle that takes up most of the screen, except the outer edges. You can see everything normally. It's just that it's the wrong color.
    The outer edges of the screen are the only areas that are normal color. The center of the circle is green and the next outer layer of the circle is purple.
    Is this caused by a supporting component that can be replaced? Or do you think the picture tube itself is gone? I solder and do some work with circuit boards. Thks!
  2. #12
    Nov 30, 2010
    16,703
    7,341
    Look into the degaussing circuit. The picture tube is not bad. It has just been magnetized.
  3. vk6zgo
    Jul 21, 2012
    677
    85
    The hissing sounds like the series PTC thermistor in your degaussing circuit has gone to thermistor heaven.
  4. sheldons
    Oct 26, 2011
    616
    101
    if you could post an image of the set displaying the fault i will be able to help you
  5. #12
    Nov 30, 2010
    16,703
    7,341
    I suspect the OP has already lost the address of this website.
