I picked up a Yamaha Su-10 little music sampler for cheap because it was sold as 'not working'. Now Ive fixed a few pieces of musical equipment before with no issues but this ones stumped me. I put batteries in and turned it on which I know I shouldn't have in hind sight but it sat there a moment before releasing magic smoke. now I thought OK blown caps. there's no sign of any magic smoke release inside the unit at all. Here are the pics I took of the power input area. The taller cap is one I replaced because the multi meter showed it as NC. Then I checked the shunt. It gets power across it just fine. The voltage regulator seems to drop though. The voltage will start high at the 9v of the power supply but quickly drop to half a volt. Could this be a fault in the regulator or something else? It doesn't do it all the time. Other times I cant read a voltage on it at all. Is there a way to test this with out ordering a replacement regulator and hoping that fixes it?
