XOR question
Jhon Paul Jaspe
Joined May 13, 2017
23
C'DE'F + CD'EF'
Can this be XOR?
Since XOR -> A'B + AB' = AxorB
if i let A' = C'E' and B = DF
then it would be like A'B + AB' ?????
and it would be like
CE xor DF ????
is this correct?
Deleted member 115935
Joined Dec 31, 1969
you only have 4 variables, so 16 states,
draw out the truth table for both,
what do you get ?
Papabravo
Joined Feb 24, 2006
22,113
No. Only two combinations of the input variables produce a 1 for an output. It is a two-state decoder, and the states are 0101 and 1010. To be sure they are complements of each other.
WBahn
Joined Mar 31, 2012
33,247
C'DE'F + CD'EF'
Can this be XOR?
CE xor DF ????
is this correct?
So expand (CE) xor (DF) into it's full SOP (sum of products) form and see if it is the same thing. It's a good exercise for you to do.
Joined Dec 31, 1969
well. that gave them the answer...
WBahn
Joined Mar 31, 2012
33,247
Not really. It's not obvious, particularly for someone new to digital logic, whether this is or is not the same as CE xor DF. After all, A xor B and AB' + A'B are each two-state decoders and they ARE equivalent.
Joined Dec 31, 1969
Re how does a truth table help,
the question was, is C'DE'F + CD'EF' the same as ???
so suggestion was,
truth table both, there are only 16 states,
if the answer is the same, then they are equvilent,
Papabravo
Joined Feb 24, 2006
22,113
so suggestion was,
That's certainly what I was thinking, but I thought I'd let someone else have a crack at it.
