XC8: .asm to C ( i.e. Lowering One's Expectations)
joeyd999
Joined Jun 6, 2011
6,548
Assuming it works (not tested yet), this is insane:
C:
    asm("BANKSEL    _ws_red");
    asm("bcf"       ___mkstr(BANKMASK(INTCON0)) "," ___mkstr(_INTCON0_GIE_POSITION) ",0");
    asm("bsf"       ___mkstr(BANKMASK(LATD)) ",3,0");
    asm("rlcf       _ws_blue,1,1");
    asm("rlcf       _ws_red,1,1");
    asm("rlcf       _ws_green,1,1");
    asm("bc         $+6");
    asm("bcf"       ___mkstr(BANKMASK(LATD)) ",3,0");
    asm("bra        $+6");
    asm("bra        $+2");
    asm("bra        $-6");
    asm("btfss"     ___mkstr(BANKMASK(STATUS)) "," ___mkstr(_STATUS_C_POSITION) ",0");
    asm("bcf        _ws_blue,1,1");
    asm("btfsc"     ___mkstr(BANKMASK(STATUS)) "," ___mkstr(_STATUS_C_POSITION) ",0");
    asm("bsf        _ws_blue,1,1");
    asm("decfsz     _ws_bitcnt,1,1");
    asm("bra        $-28");
    asm("bsf"       ___mkstr(BANKMASK(INTCON0)) "," ___mkstr(_INTCON0_GIE_POSITION) ",0");
And no, @nsaspook, there is no way to write this in C that will work.
God, the hoops I have to jump through.
Ironic: I cannot write naturally in the target MCUs natural language.
C:
    asm("bc         $+6");
    asm("bra        $+6");
    asm("bra        $+2");
    asm("bra        $-6");
    asm("bra        $-28");
Nothing unusual about that, that's why most embedded C compilers have asm capabilities.
...how stupid the code looks?
This is indecipherable gibberish -- and I wrote it.
You've been spending too much time around C.
That's the truth.
C:
        Three Phase WiFi Energy Meter (WEM3080T)
    name    Unit    Description
    wem3080t_voltage_a    V    A phase voltage
    wem3080t_current_a    A    A phase current
    wem3080t_power_a    W    A phase active power
    wem3080t_importenergy_a    kWh    A phase import energy
    wem3080t_exportgrid_a    kWh    A phase export energy
    wem3080t_frequency_a    kWh    A phase frequency
    wem3080t_pf_a    kWh    A phase power factor
    wem3080t_voltage_b    V    B phase voltage
    wem3080t_current_b    A    B phase current
    wem3080t_power_b    W    B phase active power
    wem3080t_importenergy_b    kWh    B phase import energy
    wem3080t_exportgrid_b    kWh    B phase export energy
    wem3080t_frequency_b    kWh    B phase frequency
    wem3080t_pf_b    kWh    B phase power factor
    wem3080t_voltage_c    V    C phase voltage
    wem3080t_current_c    A    C phase current
    wem3080t_power_c    W    C phase active power
    wem3080t_importenergy_c    kWh    C phase import energy
    wem3080t_exportgrid_c    kWh    C phase export energy
    wem3080t_frequency_c    kWh    C phase frequency
    wem3080t_pf_c    kWh    C phase power factor
    enum iammeter_phase {
        PHASE_A,
        PHASE_B,
        PHASE_C,
        PHASE_LAST,
    enum iammeter_id {
        IA_VOLTAGE,
        IA_CURRENT,
        IA_POWER,
        IA_IMPORT,
        IA_EXPORT,
        IA_FREQ,
        IA_PF,
        IA_LAST,
size_t iammeter_write_callback(char *buffer, size_t size, size_t nitems, void *stream) {
    cJSON *json = cJSON_ParseWithLength(buffer, strlen(buffer));
    if (json == NULL) {
        const char *error_ptr = cJSON_GetErrorPtr();
        if (error_ptr != NULL) {
            fprintf(fout, "Error: %s\n", error_ptr);
        goto iammeter_exit;
#ifdef IM_DEBUG
    fprintf(fout, "\n iammeter_read_callback %s \n", buffer);
#endif
    cJSON *data_result = json;
    data_result = cJSON_GetObjectItemCaseSensitive(json, "Datas");
    if (!data_result) {
        goto iammeter_exit;
    cJSON *jname;
    uint32_t phase = 0;
    cJSON_ArrayForEach(jname, data_result) {
        cJSON *ianame;
#ifdef IM_DEBUG
        fprintf(fout, "\n iammeter variables ");
#endif
        cJSON_ArrayForEach(ianame, jname) {
            uint32_t phase_var = 0;
            im_vars[phase][phase_var] = ianame->valuedouble;
#ifdef IM_DEBUG
            fprintf(fout, "%10.2f ", im_vars[phase][phase_var]);
#endif
            phase_var++;
        phase++;
#ifdef IM_DEBUG
    fprintf(fout, "\n");
#endif
iammeter_exit:
    cJSON_Delete(json);
    return size * nitems;
void iammeter_read(void) {
    curl = curl_easy_init();
    if (curl) {
        curl_easy_setopt(curl, CURLOPT_URL, "http://10.1.1.101/monitorjson");
        curl_easy_setopt(curl, CURLOPT_WRITEFUNCTION, iammeter_write_callback);
        res = curl_easy_perform(curl);
        /* Check for errors */
        if (res != CURLE_OK) {
            fprintf(stderr, "curl_easy_perform() failed: %s\n",
                    curl_easy_strerror(res));
            iammeter = false;
        } else {
            iammeter = true;
        curl_easy_cleanup(curl);
Reading HTTP JSON encoded arrays into double variables for a energy control program from a WI-FI three phase energy monitor.
joeyd999
Joined Jun 6, 2011
6,548
It works.
By the way, that snippet is to drive a string of WS2813s, if anyone is interested.
This is the function for 1 LED:
C:
typedef union
    uint_fast24_t rgb;
    struct
        uint_fast8_t    blue;
        uint_fast8_t    green;
        uint_fast8_t    red;
    } color;
} triled_t;
void ColorLEDPut(triled_t led)
    uint_fast8_t ws_red;
    uint_fast8_t ws_green;
    uint_fast8_t ws_blue;
    uint_fast8_t ws_bitcnt;
    ws_red=led.color.red;
    ws_green=led.color.green;
    ws_blue=led.color.blue;
    ws_bitcnt=24;
    asm("bc         $+6");
    asm("bra        $+6");
    asm("bra        $+2");
    asm("bra        $-6");
    asm("bra        $-28");
ColorLEDPut() is called once for each LED in the string. A >280uS delay between calls resets string back to LED 0.
This is written for PIC18F running at 64MHz. It will not work with slower clocks.
It works.
C:
typedef union
    uint_fast24_t rgb;
    struct
        uint_fast8_t    green;
        uint_fast8_t    red;
        uint_fast8_t    blue;
    } color;
} triled_t;
    ws_bitcnt=24;
    asm("bc         $+6");
    asm("bra        $+6");
    asm("bra        $+2");
    asm("bra        $-6");
    asm("bra        $-28");
Good job but nothing really silly or complex about that. asm is the tool for that sort of job sub-section.
cmartinez
Joined Jan 17, 2007
8,890
The worst part: converting my floating point math library to C (as inline assembly) is going to be a bee with an itch.
Knowing what you know now ... is there any kind of application out there in which you would think that using C would be a better choice than assembly? ... and I mean MCU's of course, not computers or the like.
joeyd999
Joined Jun 6, 2011
6,548
I'm sure there is. But not in my line of work.
Edit: actually, there is no such thing a "choice" anymore, at least with respect to Microchip. And not for any technical reasons.
joeyd999
Joined Jun 6, 2011
6,548
There is no technical reason why C cannot support arbitrarily sized floats.
I don't like my capabilities being limited by the whims of the author of the compiler.
That's why C makes it easy to have you own libs and asm within the source code with very few limits. The expert programmer knows best what's good for their project, not some computer science priest enforcing the latest theocratic rules from the latest language designed to straitjacket what you can do because they think something is 'ugly'.
joeyd999
Joined Jun 6, 2011
6,548
In that case, then, the IDE is the straight jacket.
No, the IDE is a supporter. It helps to protect precious things in battle.The small restriction can help you make the distance during heavy lifting.
Going Commando is cool until ...
On the ship we would Go Commando when we didn't have fresh clean water to wash clothes. We would tie pants and shirts to a rope and hang them over the fantail underway. No undies reduced the fungus in the tropics.
Rufinus General Electronics Chat 9
