It was a decent film too, a bit dated now of course but an enjoyable tense film.The 'Dam Busters' was an interesting read. also!
Came out of skipping a flat stone across the water!
Though the B-29 wasn't far behind at 20,000 lb. In fact, at least one B-29s was modified to carry TWO 22,000 lb Grand Slam bombs externally (actually the American manufactured M110 equivalent) and one was even modified to carry the 44,000 lb T-12 Cloudmaker bomb -- and it carried it internally! But these were tests done during the development of the B-36.The Lancaster had massive bomb capacity, 22,000 lbs, able to carry the largest conventional bomb of WW2 - The Grand Slam.
Ah... back when movie makers actually filmed real things doing real things.Six turning, four burning;
Some of the amazing shots of the plane!
Man, that's a big plane!Though the B-29 wasn't far behind at 20,000 lb. In fact, at least one B-29s was modified to carry TWO 22,000 lb Grand Slam bombs externally (actually the American manufactured M110 equivalent) and one was even modified to carry the 44,000 lb T-12 Cloudmaker bomb -- and it carried it internally! But these were tests done during the development of the B-36.
The B-29 had a significant advantage in terms of achievable capacity, given that it was significantly larger and had nearly twice the maximum gross takeoff weight.
Avro Lancaster and B-29 Superfortress FIFI @ Canadian Warplane Heritage Museum August 28, 2018
I still love watching a big radial fire off -- though it's so much better standing next to them! I was running flightline edge crowd control at an airshow when a P-47 demo team was getting ready to start up and they asked me to help them. I got the somewhat dubious pleasure of holding a big metal bucket up against the exhaust pipe while they started it to keep the rather large quantity of oil from spraying down the side of the plane (they wanted to make the paint finish last as long as possible). You don't get a lot closer than that! It was.... cool!
I've been onboard FiFi a couple of times and even got to spend about fifteen minutes chatting with Paul Tibbets, Jr at one of those.
But the B-36, which was all-but-ready by war's end, dwarfed both in every way with an 86,000 lb payload capacity (noticeably more than either the B-52 or the B-1). It wasn't eclipsed until the late 1980s, and then just by a bit, by the Tu-160 Blackjack.
Top shelf man, top shelf.Mosquito, Lancaster and two Spitfires
You're not as special as your mother told you you are....and we are "Generation Z".
It dosen't matter at all...fighting with us means fighting with history.You're not as special as your mother told you you are.
Like most platitudes, this is absolutely devoid of meaning.It dosen't matter at all...fighting with us means fighting with history.
She also apparently learned you not to waste time learning grammar. But, she made up for it by learning you to waste time and resources joining forums just to post meaningless platitudes.at least my mother has learned me not to waste time and resources with old deadwood lies.
Tales from the grill... | Off-Topic | 1302 | |
Tall Tales | Off-Topic | 4 |
| Similar threads |
| Tall Tales |
