Would covering a circuit introduce ESD issues
pager48
Joined Nov 25, 2018
161
Would covering a 555 timer and isolated gate driver circuit with silicone glue which hardens and is very electrically insulating cause ESD or other issues?
https://www.ebay.com/itm/133044149654
Measured this in its still liquid for with a DMM as open with probes ~2-3mm apart completely covered with it and it measures open when cured. But not sure if this can cause issues. The circuit will be enclosed in a junction box with a fan blowing air thru it.
This is the circuit to be covered.
ericgibbs
Joined Jan 29, 2010
21,562
hi 48,
I would not expect an ESD issue, but one point that should be considered is the possible self heating of any components due to the thermal insulation.
E
Tonyr1084
Joined Sep 24, 2015
9,744
ESD damage is caused by a charged item coming too close to sensitive electronics. Or in contact with a charged item. Silicone in liquid form is not going to be charged, so you're not generating any static with it. Cured silicone likewise is unlikely to cause problems. ESD is generated by separation of items. When atoms are stripped away, such as pulling tape off a tape roll generates static charges. Rubbing things together causes static. Applying silicone will not cause static damage, nor will it protect the circuitry from damage.
Electrostatic fields can pass through many items. Conductive materials such as a Velostat bag will direct the static around sensitive components. Metal containers protect. Anything that forms a Faraday Cage will protect. It also will block radio waves, so you don't want to put BlueTooth in a Faraday Cage or metal container. Not unless it has an external antenna.
The only two issues I see are heat and repairability. Even though you say heat won't be a problem, the 7805 IS going to make some heat. I don't know silicone to have better thermal conductivity than air, but if you say so and are confident - - - . As for repairability, pulling silicone off can be very damaging. Those would be my biggest concerns.
Tonyr1084
Joined Sep 24, 2015
9,744
Is covering it necessary? What sort of environment will it be in? There are spray coatings called "Conformal Coating" and come in a variety. I couldn't tell you which would be best, only that they exist. I don't think they're all that much more expensive than a regular can of paint. Oh, and don't paint your board. Probably even worse an idea than silicone.
Tonyr1084
Joined Sep 24, 2015
9,744
In the factory, when PCB's are CC'd (conformal coated) areas that should not be coated are masked off - same as you do when painting your car. Once the CC is dry you can pull the masking off the board and are left with coated and uncoated areas as per choice or design.
Tonyr1084
Joined Sep 24, 2015
9,744
Earlier I said that they were probably comparable to standard spray paint cans. I was wrong. Very wrong. Depending on what you get you can spend $15 to $150 (US). Have a look on Amazon to get an idea.
shortbus
Joined Sep 30, 2009
10,049
Epoxy is more costly.
Who said anything about epoxy? And your the only one that can judge what you circuit board is worth, and how you want to protect it. Any silicone I've ever used from a hardware store doens't flow it has to be pushed into creavices (like around chip, resistors, etc) The conformal coating are made to flow around the components and are formulated to conduct heat away from the circuit. But like all things with you, your the expert, so why even come here and ask the question?
