Wiring for a Medium-Current Relay SPST-NO, 4 Terminals, 24V DC Input
EVILPENGUIN
Joined Feb 10, 2023
Hello all,
I am new to this forum and would like help with this item.
I am a student working on an electronics project. I am trying to figure out where on this relay I am supposed to wire to. It is from McMaster and they say the wire connection type uses a screw terminal. Could someone show where I'm supposed to unscrew and attach the wiring to? Inserted below is the circuit and an image of the relay and the link to the McMaster part.
https://www.mcmaster.com/7384K16/
MaxHeadRoom
Joined Jul 18, 2013
30,885
The two screw terminals at the base of the coil , are the coil terminals , the two larger screws on the top of the relay either side of the contacts are where the load is connected that you which to switch.
EVILPENGUIN
Joined Feb 10, 2023
Is this what you are describing? Would I just unscrew those screws and then wrap or solder the wire onto them?
sghioto
Joined Dec 31, 2017
8,763
That looks correct. I wouldn't solder to those terminals, use spade lugs.
Why is there a zener diode in series with the coil, what is Vcc1?
28,595
Normally Vcc refers to Voltage, Collector Circuit, and is used with transistors. For circuits like this a better description would be "V+" .
Not trying to be critical but rather avoiding incorrect references that will be confusing in future conversations.
A serious caution is that all of the exposed metal parts of this relay are at the circuit potential and so if it is used for switching mains voltage there is a shock hazard in touching it. This caution is appropriate given the TS lack of familiarity with electrical devices.. Given the computer keyboard seen in the photos it is a puzzle. What variety of student at what level of school??
Phil-S
Joined Dec 4, 2015
241
Exactly.
If the relay type and manufacturer is known, why not do a bit of legwork and see if the datasheet can answer the questions.
it looks like something hefty, so all the more reason to be cautious.
Given the 24V DC coil, it is something more likely found in a control panel.
A bit more information on the application or the assignment would help
28,595
Really, 24 volt relays are also found in lighting controls and commercial cleaning systems, as well as HVAC systems for even medium size building. My home heating/cooling system uses a few 24 volt relays, so do parts of the lighting system. So really, aside from control panels, 24 volt relays are in many other places. Of course, most do not look quite like that photo.
MaxHeadRoom
Joined Jul 18, 2013
30,885
Many used in those applications are AC coil, the OP's is a DC version.
