Wireless transmitters (pic16f1825 has a 5 bit DAC)
Ian Rogers
Joined Dec 12, 2012
1,136
On my wireless transmitters I use 3v batteries... I then connect a voltage divider consisting of 2 10k resistors to the battery terminal to ground and read middle... BUT!! I use and internal reference of 1.5v.. (pic16f1825 has a 5 bit DAC) My system needs 1.8V to function so my percentage is 1.8v -> 3.2v. I just read the voltage which should be 1.5v max to 0.9v min.
upand_at_them
Joined May 15, 2010
939
You can simplify this *and* use less power by reading the internal fixed voltage reference, which will of course give a result dependent on your Vdd (the battery). Use a lookup table to return the result. Microchip have an app note about it, including calibration.
Ian Rogers
Joined Dec 12, 2012
1,136
True.... But nowadays I throw a solar panel on and charge a lithium cell... Never needed to monitor the battery since..
Ian Rogers
Joined Dec 12, 2012
1,136
We also use the MCP73831 when using the larger 18650 batteries... As these will last months without sunlight, then they charge quite rapidly... We use the SOT version Only a prog resistor and two external caps needed
upand_at_them
Joined May 15, 2010
939
Ian, are you using a charge controller? I'd be worried about weird charge effect, or poor charging, due to clouds-sun-clouds-sun... Any problem with that?
