Hi all, not sure I’m in the right place but can anyone direct me where to get a small push button switch that will light a small led light wirelessly when pressed. The light will be no more than 2ft from the button so probably Bluetooth or a kinetic switch? Kinetic would be awesome if no battery is required as the light only needs to go on for a second and then off. The button can’t be a click-on click-off just when you press it the light’s up for a second and then goes off, or when you release the button the light goes off. Any suggestions muchly appreciated! I’m not looking to build from the ground up just looking if there is already anything like this out there? I’m looking for both the switch and the light as a combo, doesn’t matter what colour the light is. As long as it’s small and LED. The pic attached is just a visual example. Thanks!
