Hello guys,
I would like some help with the circuit attached. First of all let me explain you the purpose of the circuit.
I am trying to build a wireless (433 MHz) pir sensor. The pir sensor is connected to the transmitter and when motion is detected, the signal is firstly encoded through the IC HT12E and then transmitted to the receiver. The transmitter is necessary to be battery operated this is why I use the transistor Q6. The problem is that the decoder in the other side (HT12D) is latching type. Therefore, in the transmitter side, when the pir detects motion, both transistors Q5 and Q6 turn on and AD8 of HT12E goes to ground. In order to get rid of the "problem of latching behaviour" of the receiver, it is necessary, at first place to turn off the transistor Q5 (invert the transmitted signal) and then stop the circuit power supply (to be able to use battery for long time). Do you have any idea why this circuit does not work as I expect?
Thank you in advance. I wish everyone to be healthy these difficult days!
