Wireless Data Transfer from a 3-axis accelerometer
mikecore33
Joined Dec 5, 2021
I'm trying to develop a wireless connection between a 3-axis accelerometer ( ADXL343 - Triple-Axis Accelerometer (+-2g/4g/8g/16g) w/ I2C/SPI : ID 4097 : $5.95 : Adafruit Industries, Unique & fun DIY electronics and kits) and a Raspberry Pi 4 with display (https://www.amazon.com/Raspberry-Touchscreen-320x480-Monitor-Display/dp/B07WQW6H9S) what type of system do I need to set up in order to transmit the data, if its even possible to? I have very little experience with Bluetooth or anything wireless. Also the system needs to be able to with stand high speed movement, as it will be attached to a boxing glove and be used to measure the speed of a punch from a boxer.
Thanks in advance
mikecore33
Joined Dec 5, 2021
I'm now thinking of using a LSM6DSO32 accelerometer for the project. I'm still needing to find a way to transmit the data from the accelerometer on the boxers wrist to my raspberry pi that will be attached to the bag. I've been told that using an Arduino would work, but I'm not sure it will communicate well with the Raspberry Pi.
tindel
Joined Sep 16, 2012
939
This seems like a pretty sophisticated embedded project. Could you use an iPhone or Fitbit or some other commercial product to do the same thing?
Being able to test and calibrate a device to know it’s measuring correctly also seems challenging. Commercial is the way to go here.
MSun
Joined Dec 22, 2021
Thanks in advance
Yes, very possible ... but a chunk of work.
There are many other Bluetooth Low Energy modules out there that already have sensors, so that may be a quicker starting place. Takes a bit of time to sort out exactly what is available, what is a good choice for your scenario, and whether it is a "ready to go" solution. For newer Raspberry Pi models, they will have Bluetooth capabilities that you can use to communicate with your bluetooth sensor module. From there, many decisions on driving the Touchscreen.
We did something similar for a customer early in the year, so definitely feasible. Just not something that is "turnkey" or easily hacked together unless you have deep software skills.
Jon Chandler
Joined Jun 12, 2008
1,649
This really shouldn't be as difficult to do as people are making out.
Use an appropriate accelerometer with an I2C interface. Use an ESP32 microcontroller to read the digital data from the accelerometer, do the necessary scaling and trimming and transmit the data wirelessly using either a direct wireless protocol (I believe there is sample ESP32 code to do this) to a receiver ESP32 or configure the first ESP32 to act as a web server.
The receiving end can be an ESP32 with an LCD display or with a little more effort, a Raspberry Pi or even a laptop. What's best depends on what you want to do with the data.
Key issues are making the sending end (accelerometer and ESP32) rugged and light weight, coming up with a reliable power supply (probably a small rechargable lithium battery), figuring out how and where to mount the accelerometer to provide representative data, and deciding how to parse the data to provide the information you desire.
I'd break it down onto pieces. Learn how to read the accelerometer with the ESP32 and output serial data. Once you have some numbers you believe, figure out how to send it wirelessly. Once you can send it wirelessly (and receive it!), figure out how to display it in a useful way on an LCD display.
mikecore33
Joined Dec 5, 2021
Use an appropriate accelerometer with an I2C interface. Use an ESP32 microcontroller to read the digital data from the accelerometer, do the necessary scaling and trimming and transmit the data wirelessly using a direct wireless protocol
Thank you for this suggestion, I'm gonna look into this microcontroller and see if it could work for my project. Right now I'm planning on using a Raspberry Pi with a built in display. So I was happy to read that it could communicate with a Raspberry Pi.
