You have the jumper wired wrong. I don't think you studied the picture
R!f@@ Joined Apr 2, 2009 10,011 May 29, 2010 #21 You have the jumper wired wrong. I don't think you studied the picture
B Thread Starter bubbagump0 Joined Jul 10, 2007 26 May 30, 2010 #23 Thanks. Should my black wire be the positive lead and red the negative? And do I need to also jump the two outside pins together where the regulator was?
R!f@@ Joined Apr 2, 2009 10,011 May 30, 2010 #24 red is positive and black is negative. Remove the jumper, and do as in the pic. The battery connections are OK If this did not work. Show me the other side of the board no jumping of the regulator.....only 1 jumper
B Thread Starter bubbagump0 Joined Jul 10, 2007 26 May 30, 2010 #25 THANK YOU SO MUCH! Wow, thank you for sticking with me so long. It works! You are quite incredible.
