Hi all,
I have 4 wind turbines, max 1000 watts each on 48 volts. (=20 amps)
And 800ah 48 volt battery array.
I have 18 X 335 watt solar panels, and on a sunny day they do produce close to 6000 watts. (Peek power production)
Clouds... :-( I am lucky to get 1500 watts.
Lucky when there are clouds,there is often wind
I bought charge controllers, and they work "OK".
Problem is the stop Voltage.
When the solar power gets the charging power up to 58 volts, the wind turbine controller brakes the turbines.
At the 58 volts the batteries are not full, about half full.
Result is during daylight the turbines don't work...
I live in Thailand, Isaan, Udon Thani province.
We have relatively low wind speeds.
Normally I would not even think about wind turbines, we live off grid.
That changes the situation for economic reasons.
In theory I could just use a simple rectifier and let the turbine do it's work.
No way it will overcharge the 800ah array.
Even with 4 turbines...
So stopping for this reason is not an issue for us.
But.
I do need it to automatically stop at high wind speeds!
They are at this moment 10 meters above the ground, I do need to do some maintenance and will bring them to ground level.
I can make some tests, to find out what RPM will make how much voltage.
Not sure if that matters.
I think just letting it stop at 65 volts or possibly at 1000 watts will do just fine.
Can this be done?
Set a "Switch" at 1000 watts?
(= Or switch at 15 amps, @ 60 or 65 volts)
My commercial controllers have an on/off switch, making the turbine to stop.
And it stops at 58 volts.
I like to be more in control.
I like to be able to set charging load.
Currently the controller need quite some wind speed to make the turbine start.
If I disconnect, the turbine spins just fine.
I guess it needs a more intelligent controller system, or more stupid
90% of the time there is low wind speed.
Low charging load with a spinning turbine is a lot better than a standing still turbine.
Naturally, it is 3 phase AC generator, 48 volts, max 1000 watts, / = 20 amperage.
Please advise!
But.
Can this be done?
Please advise!
