Wideband Amplifier help
sandeep156
Joined May 17, 2013
7
Hey
We are just trying to figure out what the cut off frequency and gain is for the non-inverting half of the wideband amplifier (image attached).
So for the non-inverting configuration, C4,C8 & C10 are not connected.
We calculated the cutoff freq using 1/(2*pi*R9*C11) and got 160Hz and the gain was found to be (1 + (R8/R9)) = 6.6.
Can someone verify if this is correct please, because we tested our circuit and got very different values? Also, if it isn't,can someone please explain how to obtain the correct gain and cutoff frequency values.
Thank you.
shteii01
Joined Feb 19, 2010
4,644
If it has cutoff frequency, then it is some kind of filter. The amplifier feature is just an extra.
What kind of filter is it?
shteii01
Joined Feb 19, 2010
4,644
From what I see it's a high pass filter.
But I'm not sure if the cutoff frequency I have is correct.
You have same signal going into inverting amplifier and none-inverting amplifier, then you combine the results, it seems to me that two results would simply cancel each other.
sandeep156
Joined May 17, 2013
7
Hey again,
We don't use both amplifiers at the same time. So, for now, I'm just testing the non-inverting one. To do that, I have disconnected C4,C8 & C10.
Do you have any suggestions how to calculate the cut off frequency?
Thanks
shteii01
Joined Feb 19, 2010
4,644
Hey again,
Thanks
I am doing it same way you are doing: fc=1/(2*pi*R9*C11), I am getting 159 Hz, so figure 160 Hz.
What did you get from the test circuit? Did you get 1.6 kHz?
sandeep156
Joined May 17, 2013
7
Hey,
So from our test, we get a constant gain of 2.5 for frequencies above 500Hz - the characteristics of a high pass filter (whereby the gain is constant after a certain frequency). At 500Hz, the gain is 0.707*2.5 (which is the cutoff point).
So both the gain and frequency are off. But there is a pattern.
Any ideas why?
shteii01
Joined Feb 19, 2010
4,644
Hey,
Any ideas why?
I am not sure.
vk6zgo
Joined Jul 21, 2012
677
Philosophically,yes.but all amplifiers have a cut off frequency.
R8,R9,& C11 control the amount of negative feedback,& hence the gain.
The gain can only be (1 + (R8/R9)) when the reactance of C11 is negligible.
Of course,there are other ramifications---when C11's reactance becomes significant,the feedback is phase shifted away from 180 degrees.
LvW
Joined Jun 13, 2013
2,038
sandeep156,
I see no reason why the gain (above the corner frequency) shouldn`t be 6.6.
Regarding the frequency dependence:
I wouldn`t say that it is a "filter" - because you do not intentionally introduce some corner frequencies. Each amplifier has an upper frequency limit (low pass action) and in case of single supply also a high pass charcteristic with a lower cut-off (necessity of input coupling capacitors). Thus, in total it is a very broad bandpass - if you like.
However, as in your circuit the time constants of both the input circuitry (c12 and connected resistors) and the feedback circuitry are of the same order, both wll contribute to the resulting lower cut-off frequency.
As an approximation you can geometrically combine both cut-off frequencies (sqare root of squared values).
sandeep156
Joined May 17, 2013
7
Hey everyone,
Sorry to get back to you guys this late.
But thank you all for your help!
@LvW - I will add both cut off frequencies as you have mentioned. Thank you.
-Sandeep
