Why don't resistor vendors list the length of the resistors they sell?
Lumenosity
Joined Mar 1, 2017
614
RESOLVED (I confused SMD sizes with Axial sizes)
And how do you buy 3.2mm length resistors in bulk quantity in an assortment of ohs ?
I need 3.2mm body length resistors.
1206, 1210, 1812, 3216, 3225 and 3246 all denotes 3.2mm length resistors in varying wattages.
However, I seldom see vendors listing the length of the resistors they have for sale...only the watts rating.
I don't understand this?
Isn't the length of resistors you are buying also important?
In the application I need 3.2mm resistors for, larger resistors are too long.
Lumenosity
Joined Mar 1, 2017
614
Ok, I see what I did there.
I confused some 1/4 watt resistors with 1/8th watt...and SMD size charts with through hole sizes
thanks
dl324
Joined Mar 30, 2015
18,298
Beware of a category of through hole resistors called something like "miniature". They're twice the power rating most of us are familiar with.
This is for Yaego resistors:
The traditional 1/4W resistor (MFR-25) dimensions can be a 1/2W (MFR50S). That seems like a bad idea to me...
38,435
Yes, I agree.
I would expect those 1/4W size resistors to get really hot if dissipating 1/2W, with likely a reduced lifetime and a change in resistance value.
There's little you can do to make a 1/4W sized resistor dissipate 1/2W other then letting it run a lot hotter (perhaps enough to scorch the PCB it's mounted on).
cmartinez
Joined Jan 17, 2007
8,750
You can always add a dedicated 5W, 12" dia ventilator running at > 3,000 blowing air directly at it ... :rolleyes:
:p
