Why does the current get low?
booboo
Joined Apr 25, 2015
168
Hey guys
I wired up this circuit:
(A DMM series with an LED to know how much current it draws)
At first when I connect the LED and turn on the circuit it starts to draw 30mA and it goes down. IIRC I have the same situation measuring the current other devices draw. is it normal? why does it happen?
booboo
Joined Apr 25, 2015
168
What is your power source?
If it's a battery, it may just be weak.
Measure the battery voltage when you do the test.
Yes, sounds like you are right.
I measured the pole of that 9v battery you are seeing in the picture and it was 3.38v and it starts to go down 3.37v,3.36v,3.35v,... about each 2-3second.
Marley
Joined Apr 4, 2016
519
Have you got a resistor in series with your LED? Or did you simply connect the LED directly across the battery?
Marley
Joined Apr 4, 2016
519
So the LED current is being controlled by the internal resistance of the battery. This resistance quickly rises as the battery discharges. As the resistance rises, the current falls.
Normally, you would connect a resistor in series with the LED. This would set the LED operating current to be much lower, extending the life of the battery.
Also, as this resistance is in series with the internal resistance of the battery (and hopefully much larger) the internal resistance has much less effect on the current.
Check out Ohms Law!
booboo
Joined Apr 25, 2015
168
Several question:
1- The battery is 9v but when the led was connected to the battery and I measured the voltage, it showed me 3.37v. why? shouldn't it be 9v?
maybe because the battery is a current source. is it correct? if not, then are all of the supplies like this?
2- Do all supplies have internal resistor? I take a glance here but it was about batteries.
OBW0549
Joined Mar 2, 2015
3,565
No, there is no resistor in series with the LED.
Then what is there to limit the current through the LED and meter? Nothing, except the ability of the battery to deliver current-- which, in this case, is pretty weak (and is probably all that prevented you from destroying the LED and/or blowing the meter's internal fuse).
ALWAYS put a resistor in series with an LED when driving it from a voltage source such as a battery or a power supply. The value of the resistor should be chosen to pass an appropriate amount of current (10 mA is a good figure) given the power supply voltage and LED forward voltage drop.
Marley
Joined Apr 4, 2016
519
Several question:
1. Because the LED is an electronic device. It is not a constant resistance. As the voltage across it increases above 3.37V the current it conducts increases very rapidly with only a small an increase in voltage. In other words, it's resistance becomes very low above 3.3V. Below 3.3V it's resistance is much higher.
2. All power supplies (of any type) have an internal resistance. Your small 9V battery has quite a high internal resistance. (Which was lucky - otherwise your LED would have gone POP very quickly!). For example: a 12V car battery has a much lower internal resistance. Good thing you did not connect your LED across that as it would have been instantly destroyed due to the very large current that would have flowed.
bertus
Joined Apr 5, 2008
23,040
The batteries will have internal resistance.
Battery | Type | Internal Resistance (Ohms)
9V | Zinc-Carbon | 35
9V | Lithium | 16-18
9V | Alkaline | 1-2
AA | Alkaline | 0.15
AA | NiMH | 0.03
D | Alkaline | 0.10
D | NiCad | 0.009
D | Lead-Acid | 0.006
Note: internal resistances shown above are at full charge and room temperature.
The table is from this page on leds:
http://www.gizmology.net/LEDs.htm
Marley
Joined Apr 4, 2016
519
A picture is better than words. I have drawn a diagram to try and explain to the thread starter why he only measured 3.37V across his "9V" battery. All to do with the internal resistance of the battery. And good old Ohm's Law!
Think of the battery as a perfect 9V supply in series with its 35 ohm internal resistance:-
hp1729
Joined Nov 23, 2015
2,304
9V | Alkaline | 1-2
AA | NiMH | 0.03
D | Alkaline | 0.10
D | NiCad | 0.009
9 V (alkaline?)
Measures 3.7 V at 30 mA. Internal resistance is about 170 ohms in his case.
booboo
Joined Apr 25, 2015
168
Two question:
1- Why don't we a resistor in series to supply other devices? transistors, Op-Amps, microcontrollers,...
2- Should I use resistor in series to other devices while I'm measuring its current?
bertus
Joined Apr 5, 2008
23,040
@hp1729
The table shows fresh charged batteries at room temperature.
The values will likely be typical values.
There will also be differences between brands and status of the batteries.
Two question:
1) transistor DO need resistors in the circuits.
Opamps and microcontrollers are active devices that will have a rated power supply voltage.
The datasheets of the devices will tell you the range.
2) It depends on the device.
As said opamps and microcontrollers will have a rated power supply range.
Marley
Joined Apr 4, 2016
519
1. Because some things have a sufficiently high resistance that the they don't need extra resistance to control the current.
2. No, because adding resistance will change the value of the current.
Current is a difficult thing for beginners to understand. The value of the current depends on the resistance of the circuit (and the driving voltage). You can't say that a battery (for example) has a "current" in itself - It always depends on what is connected to it.
Think of current like the amount of water flowing in a pipe. The flow depends on many things: diameter of the pipe, how much the valve at the end of the pipe has been opened and the pressure (the head of water) driving the flow along.
booboo
Joined Apr 25, 2015
168
Another question,
LED is a diode, right? it has a voltage drop, doesn't it?(between 0.3 - 0.7) What does drop voltage across a diode? resistor? if so, then why we use a resistor in series with it?
