Why does my AA powered motor show high voltage when running?
Lumenosity
Joined Mar 1, 2017
614
Hello.
I have a small AA battery powered desktop vacuum cleaner.
It uses 2 double A batteries
When the vacuum is not running and I check the battery voltage (combined) I get 2.95v
But once I turn ON the vacuum, the voltage surges to 7v or more.
I even measure MUCH higher voltage at the motor terminals.
I don't understand this.
However, I'm guessing it has to do with OHMs Law and the change in current?
MaxHeadRoom
Joined Jul 18, 2013
30,686
A DC motor also generates, and tends to oppose the applied voltage, this is what limits the current rather than purely the resistance of the armature.
Max.
