White box above apartment door
Iloveforums
Joined Apr 16, 2018
7
So our apartment building all has a white box on top of our doors installed by AT&T. Anyone know what the hell it does? I asked the guy who installed it, he said it’s for Internet. Kinda suspicious why would they installed one in front of each door, is it for low income? Any information would be appreciated, thanks so much
MrAl
Joined Jun 17, 2014
13,722
Take a picture of it and post it here. It could be their cable converter box, converting from fibre to coax for example.
WBahn
Joined Mar 31, 2012
32,935
Have you asked the building manager?
It's possible that they had internet infrastructure installed for every apartment (just like they have -- or at least traditionally had -- telephone service wired to every apartment) so that tenets could get internet without having to have someone come in and damage walls to run wire that becomes an undocumented mishmash over time. The individual boxes might be so that individual tenets can subscribe/unsubscribe and be billed accordingly.
If the building manager doesn't know, then you should get on them and stay on them to find out -- there's no reason that anyone should be installing something like this in the building without their knowledge.
MrSoftware
Joined Oct 29, 2013
2,273
Pop the cover off and take a picture of what's inside. Post the picture here if you don't recognize what's inside. If there are markings, including markings on chips, try to make them clearly visible in the pictures.
It does not look suspicious. It looks like a simple access/tap box. It is perfectly reasonable to have these installed in the common areas. Yes, of course, the owner/manager/business office must have given consent. But, yeah, ask and look.
Iloveforums
Joined Apr 16, 2018
7
Yeah I don’t know they should at least put out flyers or what not to let us know what they wrrr doing. They do with everything else
WBahn
Joined Mar 31, 2012
32,935
You would probably find that there are lots of things that happen around the building that you aren't notified about. Depending on the size/age of the building, there's probably stuff happening more days than not.
Tonyr1084
Joined Sep 24, 2015
9,744
Playing "Angel's Advocate" (opposite of devil's advocate) it could be a hub for some smoke / fire detection system. Nonetheless, I think you have the right to know if it's something that could be spying on you. I doubt it is, as usually such spy devices are better hidden. But then again, sometimes the best place to hide is in plain sight.
Tonyr1084
Joined Sep 24, 2015
9,744
My guess is that it's a WiFi repeater.
I wouldn't expect to see a repeater above every door. It COULD be. But typical apartment construction is where one unit has a specific floor plan and the adjacent unit has the mirrored floor plan with typically the majority of the plumbing in a common location. So that would precipitate the need to have an apartment door just some few feet away from the next, then a large gap to the next door. So if there's one of these units directly above EVERY door and the doors are in half the cases adjacent then I'd suspect it's not a repeater. One repeater should be sufficient for two apartments. Besides, wouldn't it be the occupant's responsibility to set up a router/cable service in their home?
The hotel I stayed in last winter had three repeaters in the hall. One at either end and one in the middle, and there were 16 rooms to a floor. Three repeaters for 16 units? One repeater over every door? I'm tending to think that's not the case.
