I have a power supply that outputs 12V and 5V. It has a mini-din plug with 4 pins, 2@12V, and 2@5V. I want to connect this to a fan controller which has a four pin molex connector 12V/grd/grd/5V.
Can anyone tell me where I find or what I use for a ground for this type of a connection.
The spec on the power unit are:
Input: 100-240 VAC 50/60Hz
Output #1: +5V @ 1.5A #2: +12V @ 1.5A
Specifications/Features: Removed from New Equipment Desktop switching supply. Over current protection. Std. IEC 3 wire input connector. 4ft. output cable with 4Pin Mini DIN connector.
