I'm currently "Experimenting" with some LED's. I noticed that some of the LED circuits that I have around the house have different resistor values than I would expect. I created a circuit on the Falstad Simulator http://tinyurl.com/y6ctbjoc. The values that I am seeing are different from my math. Either the website is off or I am. I am betting on the latter rather than the former. By the simulators calculations, I am above the necessary current and below the necessary voltage. Where does the extra current go, heat at the LED? Why does the LED still light up? Can anybody point me in the right direction of a simple explanation? I am familiar with the triangle as well.
I have 4 - White LED's - 3VDC - 150mA, 500mW. I am attempting to work out if its better to power these with 12v or 24. I have looked at constant current, I could go that route. I was trying to avoid the number of components i.e., going from 120VAC -> 12VDC or 24VDC Power Supply -> Constant Current Module -> LED's. I will eventually have 3 different size SMD LED's, 3 Different Colors, and three different quantities. space may or may not be limited, so I wanted to see what the possibilities are, learning opportunity too.
