13 years ago, I designed and built a test fixture to validate, during production, the performance of a transducer that I developed. This week, the fixture died a horrible death, so I had to build a new one.
Luckily, I had made extra PCBs at the time and found them in storage with most of the components required (the boards were a bit oxidized but usable). Some quick shopping at Digikey and I had everything I needed to build a new fixture.
So, I get the thing together and begin testing it. I notice that the transducer's output seems about 1/2 of that which was recorded using the old, now dead fixture. Crap. I did something wrong.
The only gain in the circuit is from an MFBP filter, and the response looks like this:
The new board follows this nearly exactly. So, I looked back at the old board. To my surprise, there was an incorrect resistor on the second stage of the filter. The response with the erroneous resistor looks like this:
This means for 13 years(!) I have been incorrectly measuring the output of my transducers. The gain was wrong by a factor of 2, and it wasn't even a good flat top bandpass centered about 10Hz (the frequency my transducer runs at). Double crap.
Fortunately, the pass/fail limits were set based upon the performance of the fixture, so this hasn't affected my production material.
But, here's my dilemma. Do I:
A) Recalculate the new pass/fail limits based on the correct circuit, or
B) Stick the old, incorrect resistor back in and use the original limits.
I would like to kick myself of 13 years ago.
