What would be the risks involved with a ESD event inside a implant containing a IC, would the high peak current be danagerous?
How are the conditions for an ESD supposed to arise inside an implant?What would be the risks involved with a ESD event inside a implant containing a IC, would the high peak current be danagerous?
During operation for example
Kind of, if a impant contained a IC or a PCB and it had a ESD event from a ESD gun for example (hypothetical/extreme) would the high peak current be dangerous to the human and would it cause the implant to fail?Ah, I think I understand what you are asking. I think you mean:
If a person has an implant, and they receive a static shock, what effect does that have on the implant?
Is that correct?
No worries, what are your thoughts on the proposed situation?The title of your thread implied that the ESD event was generated inside the implant. My mistake -- sorry.
I don't have a good understanding of the circumstances of the body's response to an ESD gun. I've used them on products for testing, but we were never foolish enough to use them on people. There are just some things you don't screw around with. I do know that survival from a lightning strike is not certain one way or the other. The people that I knew that survived were never quite the same after the incident.No worries, what are your thoughts on the proposed situation?
Even a if the electronic is a IC which has a low component rating? would death be definite even if the implant wasn't near vital organs?If you can get a current high enough to damage the electronics inside a body, you would kill the person first.
I have a PCB placed behind either ear, used for two way communication with some people manipulating and abusing me. i am trying to destroy them as soon as possible. i got a CT scan at the end of august (can be seen on scan, GP and second opinion both gave different answers and tried asking me if i think it is mental health, which it isn't because there is more to the story. Since then the PCBs have been overheating from time to time leading to skin on the surface and ear to be extremely hot and red. there is constant noise in the left side but communication in both is relatively clear. Quieter these days than a year or so ago. I saw ESD can damage electrics instantly and isn't seriously harmful to humans if precautions are taken. i am trying to work out how to safely zap these chips.Is this
Home work
A thought experiment
Finding how to kill someone ?
Re can esd damage electrical circuits , yes
Re can a circuit inside a conductive box suffer esd from outside, no,
Is the human body conductive, yes.
Most likely reason to have a current insde a person, would be a de fib.
https://www.defibmachines.co.uk/can-use-defibrillator-person-pacemaker/
it is something like a cohlear implant but it is just a PCB without any sheilding other than thin bone and protection the skin above provideWhat type of implants are you talking about? A quick search reveals that it is sometimes a problem with cochlear implants.
