What would be the definition of qualifier in c language
skyr6546
Joined Mar 22, 2019
73
Hello friends
Qualifiers and storage class are smaller but important programming concept. storage class which decides scope, visibility and lifetime of that variable.
I do not want to know their types. I know const, volatile, short, long, signed, unsigned are the qualifier in c language.
Can anyone explain what would be the definition of qualifier in c language?
sky
Papabravo
Joined Feb 24, 2006
22,115
Hello friends
sky
Same as an adjective: it modifies the noun.
Why are you kidding ??
He's not kidding. Type qualification in C is exactly that. What the qualifier does is language dependent. In C and in human languages ({baking...eating type} apple) it modifies a thing by the definition (language specification) of the adjective.
Search this link for qualifier.
http://eli-project.sourceforge.net/c_html/c.html
http://eli-project.sourceforge.net/c_html/c.html#s6.5.3
http://eli-project.sourceforge.net/c_html/c.html#s10.1.3
skyr6546
Joined Mar 22, 2019
73
How is this definition?
The keywords which are used to change the properties of a variable is called qualifiers.
Papabravo
Joined Feb 24, 2006
22,115
It is a definition like any other definition. It tells you what the thing being defined does, both syntactically and semantically. In a natural language the qualifier or adjective has to appear in proximity to the thing it is connected to. In some languages the word endings help to match qualifiers (adjectives) with the objects (nouns) they modify. I don't know if "C" allows you to reverse the order of qualifier and object as in in
short unsigned as opposed to unsigned short. I don't think I have ever seen any code that uses the former construction. The syntax rule says a qualifier must precede the object it modifies.
FWIW -- I never kid about stuff like this and I'm insulted you would think that.
