What should my base resistor value be on a BJT when running a varying current through it?
mdylanmst20
Joined Jun 5, 2017
19
I'm trying to use BJT's but want to run varying currents through it. On the the data sheet for the transistor it gives the Beta value and it changes with different collector currents. My question is if there is a range of currents running through the transistor, what should I choose as my Beta value, so I can calculate my base resistor?
dl324
Joined Mar 30, 2015
18,446
What does the circuit do?
In addition to beta varying with current, among other things, it will vary from transistor to transistor. Circuit designers generally design circuits to function with a range of betas and instead depend on a minimum beta; versus typical or maximum.
Stuntman
Joined Mar 28, 2011
222
From your description I am imagining you are not using the BJT to vary this current, instead, the current is controlled via a seperate part of the circuit while the BJT in question acts as a switch?
If so, why not pick a minimum beta and maximum current condition and set your base current accordingly?
OBW0549
Joined Mar 2, 2015
3,565
Choose the specified minimum value of beta at any collector current in your range of interest, calculate the maximum required base current from that value of beta, and calculate a resistor value that will give you at least that much base current, plus a bit extra for a margin of safety.
