What should be the output voltage of a step down transformer for a 10amp car battery charger
B Bobby
Joined Oct 6, 2018
8
I was looking to create a 10amp manual charger with variable voltage and current option for flooded lead acid battery (normally used in cars).
I only know some basic electronics and usually make solutions by integrating off the shelf modules.
For this project I have to first buy or order a custom built 10amp step down transformer but I was bit confused what should be the secondary output voltage for this transformer
To charge a FLA battery we usually need up to 14.2V and to equalize we need 15V that is maximum output we need from a battery charger
Therefore my question is should I look for a transformer with exactly 15V secondary output? or higher than this and why?
Thanks,
38,426
Depends upon the voltage drop you current/voltage control circuit will require.
And the DC voltage from a rectifier-filter is about 1.4 times the RMS AC transformer voltage, so for 15Vdc you would need at least an AC output of 15V/1.4 = 10.7Vrms from the transformer.
Typically you would likely use a transformer with a standard output of 12.6Vac.
A custom-built transformer for this would be rather expensive. :eek:
B Bobby
Joined Oct 6, 2018
8
Many thanks for this valuable information
ian field
Joined Oct 27, 2012
6,536
Thanks,
A lot of basic chargers had "impedance wound" transformers that intentionally have lousy regulation. the electrolyte in a flat battery is not far off pure distilled water and not easy to get any charging current on the move. it can take around 30V to get going if a flat battery is showing first signs of sulphation - maintaining that voltage after it starts drawing current wouldn't end well!.
A linear electronic charger suggested in yuasa literature starts with constant current at 1/3 of Ah rating and 29V capability. The voltage will be pulled down as charging current picks up. a comparator detects 10.8v and latches a flip flop that switches over to constant voltage charging. You should probably aim for about 14.4V - that will gas the distilled water away after a while. Smart chargers usually drop back to about 13.6V. A good compromise is about 13.8V, but you still can't leave it float charging for months.
B Bobby
Joined Oct 6, 2018
8
Thanks for this great info,
Does this mean I should have a power supply with 29V voltage output but of course voltage cutoff will be happened at 14.2V or 14.4V?
Actually I wanted to have this charger only for occasional battery maintenance. The 3 or n-stage automatic chargers sometimes refuse to charge a battery which somehow went below 10v or 9V.
Therefore my idea was to just have a power supply with a voltage cutoff module to prevent any overcharge, other than this no other complex charging routine using micro-controllers
ian field
Joined Oct 27, 2012
6,536
you don't seem to have taken much notice of what I said - charger transformers deliberately have lousy regulation so the off load voltage is high enough to get a flat battery to take charging current. A "stiff" transformer that can get it going, will buckle the plates when it starts drawing current.
I'd probably use a general purpose equipment transformer that gives about 30V after rectification - a current limit circuit is then REQUIRED.
Its just so much easier to nip in a discount store and get a semi-smart fast charger - the smart or "maintenance" types are usually very slow.
