Do you mean 0.025" square?
Do they need to be gold plated and as individual pins?
Then @Wendy 's must be 0.025" too? What's the point of your posts?FWIW, I measured some wire wrap sockets from the 70's (Augat and Textool). Both measured 0.024-0.025".
My point is that they must be 0.025". If that's the case, there are many sources for those parts and in a number of lengths.Then @Wendy 's must be 0.025" too? What's the point of your posts?
You can try inserting them into a female header or shorting block. If they go in without much effort, they're probably male header pins or similar.While I have no idea if calipers are accurate to that small of a dimension
Blind faith could be problematic. Trust but verify might be a better philosophy. Has the tool ever been abused/dropped? Is it analog or digital?I was taught to trust your instruments
Those are all 0.025" square. If that size will work, Vector carries a number of pins; assuming you don't require gold plating.The ones shown on post 10 look very promising.
Mouser has 100 for $12.66. If you buy 1000, the price drops to $0.074 each. Jameco sells 100 for $10.95.Amazon sells these. A bit pricey at least there is no minimum order. There is 100 per package.
