Hello everyone, does anyone know what this is? Is it a laser trimmed thermister?
Sorry Keith.Do we get any clues?
What is it out of?
How big is it?
Does it have any wires attached to the back? If so, how many?
What is it made of?
Have you made any electrical measurements on it?
Is this part of something?
Did it have a cover on it?
Thanks Ernie. It only had two solder points... should not there be 3?That is a BJT transistor. A Darlington I suspect.
It helps when you have a background in hybrids, or worked at a transistor foundry. I've done both. ;-)
Nope. Just two. The collector is the backside.Thanks Ernie. It only had two solder points... should not there be 3?
Wow!! That is cool !Nope. Just two. The collector is the backside.
Here's one in a TO-3 case. The TO-3 case is the collector so having the whole backside of the die being the collector means you can mount one to another for the best electrical and thermal conductivity.
Thanks Darth.... that was my line of thinking at the beginning !!Based on the wiggly shape, it makes me think of delay lines, or PCB RF antenna's, but that's WRONG LOL
