What is this called ?
MaxHeadRoom
Joined Jul 18, 2013
30,661
Probably a custom PCB edge connector, the PCB side may have to be custom made by a board producer, there are many out there, a schematic capture program could be used to mock it up..
Max.
Ya’akov
Joined Jan 27, 2019
10,235
Welcome to AAC.
That is a custom PCB Edge Connector.
You can replace it if the manufacturer has parts. Failing that, you could theoretically reproduce it. However. assuming replacement parts are not available, repairing the traces—the copper tracks on the circuit board—is possible.
Ya’akov
Joined Jan 27, 2019
10,235
Max.
Beat me by seconds, Max. I think the hardest part would be cutting it. However, I should add, it is important to figure out why it burned or it might just happen again as soon as it is plugged in. It is unlikely the board itself is the root cause of its own demise.
Reloadron
Joined Jan 15, 2015
7,889
I agree with Max and Yaakov as it looks to be an edge card connector of sorts, likely custom. However, since it is just a passive connector the damage you see is likely only a symptom. Something, likely very high current, caused the burning and failure so you are looking at a symptom. Even if you found another or made another it would likely burn up until you find the cause. There is a reason it burned up. You need to find the cause of the symptom you are seeing.
Ron
