I have a 2.4v 3800 mAh battery pack (2 1.2v batteries in series. They are connected to a 3-wire connector (red is positive, black is negative, and white is also negative but appears to have a bead thermistor on the white line.
What is the purpose of the thermistor (this battery pack powers a mechanical baby one might use in a high school class where you are required to take the baby home)?
I unhooked the thermistor and measured 9,300 ohms across it. The thermistor changed its base value when i applied heat up to about 9,600 ohms.
How would I identify a replacement part for the thermistor?
