What is the role of NE555 in this fire alarm circuit?
christw16
Joined May 31, 2018
21
Here is the diagram of fire alarm
when I use lighter to burn at the thermistor, the speaker rings
In this circuit, what is the role of ne555?
Thank you!
wayneh
Joined Sep 9, 2010
18,100
It provides a tone to drive the speaker and make noise. The transistors enable the timer, allowing it to run.
absf
Joined Dec 29, 2010
1,968
T1 is NPN transistor BC548 and
T2 is PNP transistor BC558.
Both will conduct when the thermistor is heated.
DickCappels
Joined Aug 21, 2008
10,661
Like absf said in post #4, T1 is an amplifier while T2 switches on when current from T1 is high enough, enabling the NE555 to oscillate, producing the tone that wayneth mentioned in post #1,
