What is the name of the component in the picture?
eonshopact
Joined Sep 2, 2023
19
What is the component name seen in the picture. Why the chip is missing in the component(green colored pin board).
KeithWalker
Joined Jul 10, 2017
3,606
I see two pictures, not one.
I see a number of components. Which one are you asking about?
I don't see a green circuit board. They are both blue.
If a chip is missing, It will be because someone removed it or it was never there.
Can you be a little more specific with your questions please, so we can try to give you some reasonable answers.
eonshopact
Joined Sep 2, 2023
19
1. I want both the boards name.
2. In the first picture the IC is missing i think. If it is missing, then which IC?
The modules/components are in my lab. I tried to find the answer by image search in the google. Google is showing the first image as Motor driver l293d. But, the IC can be seen in the google image. For the second image, the google is showing it as l293d motor driver shield. I want to confirm this with experts in this forum.
dl324
Joined Mar 30, 2015
18,326
We can only get so far with just a couple of pictures; one poorly focused at that. On the other hand, you have the board and can trace it.
The first likely connects to two motors. The second is a "motor control shield for Arduino" from MH Electronics.
It'd be more appropriate to call them boards or modules, not "component in the picture".
eonshopact
Joined Sep 2, 2023
19
The first image, does not have any number/name. I think, IC itself is missing (you can see in the image).
