The loop antenna should be copper wire with a square shape,it can be about 13cm length for 2.4Ghz or 32cm length for 1Ghz.I understand that the loop should be in resonance,so i don't understand why do i need to add the inductor?1. I do not know what frequency you need to fix.
For the convenience of modeling (process speed), I used a frequency of 10 megahertz.
The magnetic antenna at this frequency is an inductive impedance.
I arbitrarily pictured frame inductance and the voltage source.
Tell me what frequency you need and what kind of loop antenna you are using.
Then I may clarify an equivalent circuit.
I saw your third diagram and it seems that the second one(Sziklai pair with one germanium transistor and one silicon) is the most suitable.
Is it safe to leave the base without any resistor that will limit the current?2. Resistor 100k greatly reduces the sensitivity of the whole scheme and need for this resistor is not.
Won't it damage the transistor?
Refer to adding a tank circuit for selectivity,i read about the series tank circuit and paralell one.
But i couldn't figure out,how to add it to my circuit or how to determine the value of the capacitor and the inductor.And if it won't disrupt the circuit at all.
I saw the formula:f = 1/2π√(LC),and i can find C if i know the L and opposite,but there are a lot of combinations that can give the same f,while i saw that it is necessary to add a resistor to the parallel tank circuit.
This is beyond my knowledge and i may need assistance with that.
