I have a need to control the speed of a number of different fans, and find all solid state solutions quite noisy. I have several Variacs in locations where fan noise should be kept to a minimum, but in others I have solid state, as Variacs aren't that cheap.
I have this specialized motor speed control.
https://www.greenheck.com/shop/accessories/speed-controls/385031
It is much nosier compared to a Variac. So I decided to compare this Greenheck to a 1980's Lutron incandescent light dimmer that I had in the parts bin. Put a clamp on the output of both and looked at the output on an o-scope. Identical! There was no difference in the wave whatsoever.
So the question is, is there really such a thing as a purpose built solid state motor speed controller? Or are they basically just a light bulb dimmer in a different box?
