What is happening in this circuit?
geminax
Joined Dec 12, 2018
Hi, I was given a question to express Vload in terms of Rload, R and Vth. However, I am a bit confused as to what exactly is going on at Vout_a.
Assuming the op-amp is ideal, I first made statements regarding what voltages were equivalent.
Vload = Vout
Vout = Vn (negative terminal of op amp)
Vn = Vp (positive terminal of op amp)
Vp = Vout_a
The problem that I run into is figuring out what Vout_a is. I tried doing KCL at that node, but all i get is that Vout_a is equal to Vth since no current can pass through the input terminals of an op-amp. And that's where I'm stuck because a lot of things just don't seem to add up with my thought process
ebp
Joined Feb 8, 2018
2,332
What would make Vout_a differ from Vth?
Is the expectation that you analyze this on the assumption of an ideal op amp or a real op amp? It makes a big difference, not necessarily in the magnitudes but in the complexity of the equations required. It you can use an ideal amp, what do you know about the characteristics of an ideal amp?
geminax
Joined Dec 12, 2018
I believe we are analyzing this on the assumption of an ideal op amp. Since an ideal op amp has infinite input impedance, no current would travel. I'm also considering the characteristic of a buffer op-amp, Vout = Vin. Therefore, Vout would be equal to Vth? But how can that be true if there is no current traveling?
And the resistor would mean a voltage drop if there was current traveling, no?
WBahn
Joined Mar 31, 2012
33,326
Vload = Vout
Vp = Vout_a
That no current flows and, as a result, Vout_a is equal to Vth is precisely the point of using the opamp.
WBahn
Joined Mar 31, 2012
33,326
Since the op amp is just a buffer, can I just act like it isn't there? Meaning Vload is just Vth - IR
Which 'I'? Iload?
Is Iload the current flowing in R?
If not, then you can't just through the nearest I and the nearest R at Ohm's Law.
WBahn
Joined Mar 31, 2012
33,326
Current traveling where? You need to be specific.
In the load? There IS current flowing in the load.
In R? If there were current flowing in R, the that would require that Vout NOT be equal to Vin.
And don't forget that an opamp is also connected to a power supply.
Again, traveling where? Yes, there would be a voltage drop across a resistor IF current is flowing in THAT resistor.
You are trying to assert that R and Rload are in series (meaning that whatever current flows in one must flow in the other). NOT the case!
geminax
Joined Dec 12, 2018
So what is the case then?
What I think to be true:
No current flowing through R.
There is obviously current flowing through R_LOAD
Vout = Vn = Vp = Vout_a
My question is where does Vout_a get its value if there is no current flowing on that LEFT side of the circuit
Jony130
Joined Feb 17, 2009
5,601
Yes.
This is wrong. Because the opamp will "set" his output at Vin.
From the external voltage source (Vcc , Vee) and internal circuit inside opamp ensures that Vin=Vout in this case.
https://www.allaboutcircuits.com/te.../chpt-8/single-ended-differential-amplifiers/
https://forum.allaboutcircuits.com/...ns-but-im-troubled-by-them.64696/#post-444315
WBahn
Joined Mar 31, 2012
33,326
It get's its value from the voltage source.
Image two drums filled with water and with a pipe one the ground connecting them at the bottom. The only way for there to be no flow in the pipe is for the fluid level in both drums to be the same. If you start out with fluid in one drum and not the other, then fluid will flow (and there will be a pressure drop across the pipe) but only until the fluid levels match. It's the same here. Initially a very small amount of current flows but after a fraction of a nanosecond (maybe a bit longer), things have equalized and the voltage at the opamp input is essentially identical to the supply voltage. Otherwise, current would flow but, with no where to go, it would result in the voltage at the opamp input moving even closer to the supply voltage.
38,932
A significant reason for using a op amp as a follower is so that the output current is provided by the op amp and is not seen by the source voltage, and thus the output voltage equals the input voltage independent of load and source resistance (within the capabilities of the op amp of course).
