I want to design a clock which set date,time with push button.
how i define variables which store data in eprome and set date,time
code define in C++
code define in C++
#include<pic.h> //include MCU head file
__CONFIG(0x1832);
//__CONFIG _DEBUG_OFF&_CP_ALL&_WRT_HALF&_CPD_ON&_LVP_OFF&_BODEN_OFF&_PWRTE_ON&_WDT_OFF&_HS_OSC
#define i_o RB4 //1302I_O
#define sclk RB0 //1302 clock
#define rst RB5 //1302 enable bit
// unsigned char time_rx;
unsigned char time_rx @ 0x30; //define receive reg.
static volatile bit time_rx7 @ (unsigned)&time_rx*8+7; //receive reg highest.
//static volatile bit temp0 @ (unsigned)&temp*8+0;
void port_init(); //port initilize subroutine.
void ds1302_init(); //DS1302 initilize subroutine.
void set_time(); //set time subroutine.
void get_time(); //get time subroutine.
void display(); //display subroutine.
void time_write_1(unsigned char time_tx); //write one byte subroutine.
unsigned char time_read_1(); //read one byte subroutine.
void delay(); //delay subroutine.
//define the time: sec,min,hour,day,month,week,year,control word.
const char table[]={0x00,0x58,0x12,0x8,0x3,0x06,0x06,0x00};
//define the read time and date save table.
char table1[7];
//define the display code for display 0-9
const char table2[]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90};
//main routine.
void main()
port_init(); //port initilize.
ds1302_init(); //DS1302 initilize.
while(1)
get_time();
display();
//DS1302 initilize.
void ds1302_init()
sclk=0; //pull low clock
rst =0; //reset DS1302
rst=1; //enable DS1302
time_write_1(0x8e); //send control command
time_write_1(0); //enable write DS1302
rst=0; //reset
//set time.
void set_time()
int i; //define the loop counter.
time_write_1(0xbe); //
for(i=0;i<8;i++) //continue to write 8 bytes.
time_write_1(table); //write one byte
rst=0; //reset
//get time.
void get_time()
int i; //set loop counter.
time_write_1(0xbf); //
for(i=0;i<7;i++) //continue to read 7 bytes.
table1=time_read_1(); //
rst=0; //reset DS1302
//write one byte
int j; //set the loop counter.
for(j=0;j<8;j++) //continue to write 8bit
i_o=0; //
sclk=0; //pull low clk
if(time_tx&0x01) //judge the send bit is 0 or 1.
i_o=1; //is 1
time_tx=time_tx>>1; //rotate right 1 bit.
sclk=1; //pull high clk
sclk=0; //finished 1 byte,pull low clk
//read one byte.
TRISB4=1; //continue to write 8bit
for(j=0;j<8;j++)
time_rx=time_rx>>1; //judge the send bit is 0 or 1.
time_rx7=i_o; //put the received bit into the reg's highest.
TRISB4=0; //finished 1 byte,pull low clk
sclk=0;
return(time_rx);
//pin define func
void port_init()
TRISA=0x00; //a port all output
TRISD=0X00; //d port all output
ADCON1=0X06; //a port all i/o
TRISB=0X02; //rb1 input, others output
OPTION=0X00; //open b port internal pull high.
PORTA=0XFF;
PORTD=0XFF; //clear all display
