Is there any experience person could recommend a good 2.4Ghz signal amplifier pin package IC DIP8 or 16 pin or SOP8 or 16 based on experience/knowledge.
I want to amplify 4G signal from an input antenna and output to another antenna...should be for transmitting.Hello,
For waht do you want to use the amplifier?
For transmitting or receiving?
Bertus
Yes exactly 4G amplifier or 4G repeater...those are expensive stuff so if i could make it my own using available especially with SOP 8/16 or DIP 8/16 would be greatHello,
What you are looking for is not simple to make.
You want a 4G repeater:
https://www.amazon.com/s/ref=nb_sb_ss_i_7_4/138-0773714-8899341?url=search-alias=aps&field-keywords=4g+repeater&sprefix=4g+r,aps,302&crid=2TIIK9K9LHTKN
Bertus
