What integrated circuit IC is used in NET energy meters ?
Externet
Joined Nov 29, 2005
2,681
Greetings.
What chip does the directional energy reading in a NET meter ? Any application notes/schematics ? [240VAC split phase]
The image below shows the moment the utility company is (rEC) RECeiving power <-- from the dwelling and the accumulated RECeived KWh energy; it periodically cycles to a DELivered display with the utility-to-dwelling energy figures :
erintse
Joined Aug 16, 2023
One commonly used Energy Measurement IC for a split-phase 240VAC setup purpose is the ADE7753, which is a single-phase energy measurement IC produced by Analog Devices. For detailed schematics or application notes, you'd better check the datasheet of ADE7753.
Hope it helps.
