What does resistor R1 do in this circuit?
Jopee
Joined Jun 30, 2024
41
This is a simple DC to DC Power Supply. It is from a book called "The Basics v3 Intro to Electronics". I don't understand what is the point of resistor R1. If I remove R1 the circuit still works normally. I still get the same output voltage when I turn potentiometer to max and led is just as bright.
Jopee
Joined Jun 30, 2024
41
Given that we do not have any specifications or description of operation of the cicuit, all of the guesses are correct.
Here is the description from the book. It just says you can regulate between 0 volts to 9 volts and led lights up when there is voltage across the output. It doesn't mention R1 at all.
WBahn
Joined Mar 31, 2012
33,260
You might look for a better book, as this one appears pretty sloppy. They should definitely describe the purpose of each component, and also why the particular value was chosen.
They claim that the LED lights up whenever there is voltage at the output. This isn't true. Set the voltage to 1.5 V (a very reasonable and useful output voltage if you are trying to test circuits intended to operate off something like an AAA battery) and the LED won't be lighting up.
It also implies that you can get an output voltage all the way up to 9 V, which is not the case since if the transistor is conducting, you will have the Vbe drop and since the base voltage can't exceed 9 V, the output voltage can't get up above 8.3 V to 8.4 V.
