What do I need for a good power electronics circuit and PCB design?
Morad Tamer
Joined Oct 21, 2016
34
Hello everyone
I want to design a High Power Relay Board which I intend to use to turn on and off air conditioners, heaters and other devices that can draw more than 2500 Watts
I want to be able to control up to 7500 Watts, 30 Amps at 250 Volts AC (Yeah that's really a lot but I like to have extra headroom)
I know of Optical Isolation and Spark Gaps so I have a bit of background on the topic but really not a lot about when to use them and where to put the components
I have never made a PCB before
The thing that made me come here (I hope this is the correct Sub-Forum to post in) is that Dave's videos from EEVBlog are sooooooo long and boring
Thanks in advance
Hello everyone
Thanks in advance
Is this for equipment permanently installed then? I ask because you won't get 30A out of a single phase GPO and if you are using 3 phase you have a bigger job than you may have thought.
Optical isolation and spark gaps; how would they be relevant?
If the control side is a low voltage environment and not generally electrically isolated from the user or conductors that the user may be able to touch then the area you need to know about is safety isolation barriers, not spark gaps. But first, please indicate; single or multiphase power and nature of control side, ie low voltage? user accessible? connected to other circuits that are user accessible? I need to know the answers before I can go much further with speculating your application.
Hymie
Joined Mar 30, 2018
1,347
Hello everyone
Thanks in advance
Someone has already designed and manufactured it for you:-
https://www.ebay.co.uk/itm/4-Channe...137541?hash=item239e446405:g:YtMAAOSwskJalRW~
Morad Tamer
Joined Oct 21, 2016
34
Well my idea is that this board will be put at the junction box and have the wiring done through it along with an Arduino for the control signals to a MOSFET which will control the voltage level of the Relay (haven't decided yet on 12 vs. 24 Volt Relays)
I am not working with 3 Phase power here and there should be no physical user interactions after the initial setup
If the entire thing is insulated such that there are no user accessible conductive parts then the low voltage circuits do not need isolation from the mains at all. But beware, you still have to develop this thing and so on, so isolation might be a good idea anyway.
Just to be clear, if you have, for example, a temperature probe and the circuit it connects to is not isolated properly from the mains (and that typically means a clear barrier of 6.4mm or more) then the entire low voltage circuit must be assumed to be at mains potential and will still require a 6.4mm clear barrier between it and anything the user could possibly touch. so the lead to your probe would need to be double insulated as would the probe itself etc etc. My advice, for what it is worth, use relays with the barrier inherent (easiest way to get the isolation) and maintain the physical separation between mains parts and conductors (relatively easy to do) and you are safe and can sleep easy at night. Sorry if this is teaching grandma to suck eggs.
