What can I do to transform a regular desk into a proper soldering place?
rambomhtri
Joined Nov 9, 2015
606
Hi, I have a regular desk in my room. It's were I sold and fix electronic stuff, but many times, my desk is "full" of traces of solder, little balls of solder, tiny cables...
Should I use something like a cover metal plate or something like that, so my desk does not get dirty?
I was thinking about something like this:
That metal plate would cover almost all my desk table, where I would put the soldering iron station and all the stuff so I could solder over it.
Do you have any better advice or tips to transform a regular desk (intended for people to read or study) into a temporal work space?
bwilliams60
Joined Nov 18, 2012
1,450
First of all, a conducting surface such as your metal plate is about the last thing you want to use. I am not sure what country you are in but Google soldering mats and you will come up with literally hundreds of sites. Find a good anti-static mat that fits your size and needs. If you want to go on the cheap side, find al old used mudflap from a highway tractor (transport) and it will suffice until you are ready to get the real deal.
rambomhtri
Joined Nov 9, 2015
606
Yeah, better, a soldering mat. I just found a blue one. It's $50, what the heck!?
I guess I could buy one under $10, right?
ericgibbs
Joined Jan 29, 2010
21,421
hi,
I make a thin plywood base, say 3 to 5mm thick, big enough to provide a work area.
Fit a 3 inch vertical piece of wood along the back edge and 2 inch pieces along the each side, so it looks like a open fronted drawer.
The vertical pieces of wood are to stop bits rolling off into oblivion.
If you want to use your desk as a desk, just lift off plywood base drawer, with all the electronic bits on it and place it elsewhere while you use the desk.
E
rambomhtri
Joined Nov 9, 2015
606
hi,
E
Oh, thank you, but wouldn't a wooden base get burnt?
I mean, you're not supposed to touch any base with the soldering iron tip, but...
Anyways, I think it's a great idea and the most economic one.
34,714
I use a rubber doormat with course upright bumps on it.
It provides electrical isolation and prevents small nuts and screws from disappearing off to the floor.
OBW0549
Joined Mar 2, 2015
3,566
I cut out a large rectangle of corrugated cardboard the size of my desktop from the box the flat-screen TV came in and use that as my work surface. Works great, and it's still in good shape after 5+ years.
Stuntman
Joined Mar 28, 2011
222
I bought this kit some time ago:
http://www.apogeekits.com/antistatic_mat_astmg1.htm just the mat
http://www.apogeekits.com/esd_workstation_abws2.htm Full Kit
I has a very nice setup for using not only an ESD mat, but all the stuff to use the ESD wristband.
$55 seems stiff, but you will be much happier have at least one layer of protection from zapping parts.
Just so you know, I bought these for the workstations at work as well. They have now seen years of heavy use by a number of people including the sometimes-careless summer interns. They are quite durable.
ETA: Wrong part number, gave the mat, not the kit
Moderators note: corrected the first link
hp1729
Joined Nov 23, 2015
2,304
I second the glass suggestion. Anti-static concerns are another question.
ericgibbs
Joined Jan 29, 2010
21,421
Personally I would not recommend glass, with a little rubbing with fabric, your sleeves etc, it can build up a high static charge.
E
