I just purchased an AC/DC power supply to generate 12VDC. I have two -V terminals and two +V terminals. I have read that the -V terminals can be used as a -Voltage supply or as the circuit's ground.
1) Can the -V terminal be used as the circuit ground (return) ?
2) Can the circuit ground be connected directly to the AC neutral (white) wire ?
