What are the parameters that I should take into consideration when replacing a MOSFET?
Xavier Pacheco Paulino
Joined Oct 21, 2015
728
I found an IRL630 Power MOSFET (datasheet attached) which is shorted, so I have to replace it. However, I dont' have the same one. I have STP16NS25 and BUZ31LH (Datasheets attached). I wonder if they could be useful. IRL630 has VDS=200V, the same as STP16NS25 and BUZ31LH.
IRL630: https://www.vishay.com/docs/91303/sihl630.pdf
STP16NS25: http://www.st.com/content/ccc/resou...df/jcr:content/translations/en.CD00002244.pdf
BUZ31LH: https://media.digikey.com/pdf/Data Sheets/Infineon PDFs/BUZ 31LH.pdf
wayneh
Joined Sep 9, 2010
18,184
1. Basic type, N or P
2. Voltage rating
3. Current ratings
4. Size and pinout
5. Logic level or regular
Once you filter on those characteristics, there are usually only a handful of choices. If the application is nothing unusual, ie frequency below 100kHz, that’s pretty much it. At high frequency, there are additional considerations such as gate capacitance.
