What are the disadvantages of adding capacitors to car battery / alternator?
dante_clericuzzio
Joined Mar 28, 2016
246
I know a little about the capacitor will stabilize voltage flow and minimize the tiny fluctuation of voltage by the alternator. But i would like to know are there any drawbacks of adding capacitor for example electrolyte 4700uF to the battery (alternator)?
Papabravo
Joined Feb 24, 2006
22,065
I don't think you would notice much effect in normal operation. The internal construction of a battery looks like a large number of parallel plates separated by an electrolyte. In the automotive environment, one of the big worries would be the "load dump" which happens when powered loads are disconnected from the battery while it is being charged by the alternator. Any capacitor in parallel with the battery would need to avoid an overvoltage failure during this time. I certainly would not risk the destruction of a $20,000 - $50,000 vehicle just to run the experiment.
https://en.wikipedia.org/wiki/Load_dump
ronsimpson
Joined Oct 7, 2019
4,662
The battery acts something like a capacitor. You would have to add enough capacitance to be equal to a car battery to make a difference.
I have worked on busses, trucks and train cars where the back end is a long way from the battery. In this case a capacitor in the back would make a difference, in the back.
LowQCab
Joined Nov 6, 2012
5,101
If You just want to quiet-down the usual noise,
a massive 2-Farad Capacitor, like used with extremely High-Power Car-Stereos,
will do a pretty good job, but only if it's connected with ~6-gauge Wire or larger,
and, You can't mount it under the Hood with all that Engine-Heat,
it has to be mounted inside the car.
Never use the car-body for a Ground connection,
and make sure that the body of the car is well connected to
the Battery-Negative, or the Engine-Block, or both,
with a heavy-Battery-cable and clean and tight connections.
27,316
The down sides of installing a 4700Mfd capacitor shunting a 12 volt battery in a normal automotive installation are the increased leakage because of the capacitor being in a hot location. The effective internal series resistance of a normal capacitor is much greater than the effective internal resistance of an automotive battery in good condition. That means that the capacitor will not help stabilize the voltage. But if the battery is an older second battery powering a high powered sound system then there may be a benefit. But that will really need to be a 4700 FARAD battery to benefit much.
dante_clericuzzio
Joined Mar 28, 2016
246
Very good -- i am looking for someone like you with real experience doing this...what is the capacitance value you are using to make it work at least i meant like for 12 volt car battery with alternator generating around 14.2 volt and fluctuate between 14.2 ~ 13.7 volts when most of the electronic are turned on especially the A/C.
dante_clericuzzio
Joined Mar 28, 2016
246
Nice thank you for the good advice - I am taking it!
dante_clericuzzio
Joined Mar 28, 2016
246
Good insight ...thank you
MrSalts
Joined Apr 2, 2020
2,767
The AC is mostly powered mechanically (look at the serpentine belt on your engine pulleys) so, not much of an electric load.
Charging with clean DC is more likely to build sulfate bridges and shorten the life of a lead-acid battery. Note, I've never seen a battery charger with capacitors, just simple rectified DC from the transformer.
dante_clericuzzio
Joined Mar 28, 2016
246
Thank you for some of the realization.
27,316
Mr S makes a good point that I had not considered, about battery charging. But consider that the variation in battery system voltage is very well known, what sort of problem is there in having that variation? Any well designed 12 volt powered devices for automotive use can handle the variation quite well.
So I am wondering as to why the variation is a concern? All of the varied tape players that I have used in cars had enough motor speed control to function properly with those variations.
I did once ride in a vehicle that had a failed battery such that we always had to push start it. The headlights did dim and brighten with the engine speed. But driving with a failed battery is not close to normal operation.
